Represents a string array metadata property in EXT_structural_metadata. More...
#include <CesiumGltf/PropertyView.h>
| PropertyView () | |
| Constructs an empty property instance. | |
| PropertyView (const ClassProperty &classProperty) | |
| Constructs a property instance from a class definition only. | |
| PropertyViewStatusType | status () const noexcept |
| Constructs an empty property instance. false>status | |
| const std::optional< std::string > & | name () const noexcept |
| Constructs an empty property instance. false>name | |
| const std::optional< std::string > & | semantic () const noexcept |
| Constructs an empty property instance. false>semantic | |
| const std::optional< std::string > & | description () const noexcept |
| Constructs an empty property instance. false>description | |
| int64_t | arrayCount () const noexcept |
| Constructs an empty property instance. false>arrayCount | |
| bool | normalized () const noexcept |
| Constructs an empty property instance. false>normalized | |
| std::optional< PropertyArrayView< std::string_view > > | offset () const noexcept |
| Constructs an empty property instance. false>offset | |
| std::optional< PropertyArrayView< std::string_view > > | scale () const noexcept |
| Constructs an empty property instance. false>scale | |
| std::optional< PropertyArrayView< std::string_view > > | max () const noexcept |
| Constructs an empty property instance. false>max | |
| std::optional< PropertyArrayView< std::string_view > > | min () const noexcept |
| Constructs an empty property instance. false>min | |
| bool | required () const noexcept |
| Constructs an empty property instance. false>required | |
| std::optional< PropertyArrayView< std::string_view > > | noData () const noexcept |
| Constructs an empty property instance. false>noData | |
| std::optional< PropertyArrayView< std::string_view > > | defaultValue () const noexcept |
| Constructs an empty property instance. false>defaultValue | |
| PropertyType | propertyType () const noexcept |
| Returns the PropertyType of the property this view is accessing. | |
| PropertyView (PropertyViewStatusType status) | |
| Constructs an invalid instance for an erroneous property. | |
| PropertyView (const ClassProperty &classProperty, const PropertyTableProperty &, const CesiumGltf::Enum *) | |
| Constructs a property instance from a property table property and its class definition. | |
Protected Attributes | |
| PropertyViewStatusType | _status |
| Indicates the status of a property view. | |
Definition at line 2501 of file PropertyView.h.
Definition at line 2506 of file PropertyView.h.
Definition at line 2519 of file PropertyView.h.
inlineprotected |
| status | The value of PropertyViewStatus indicating the error with the property. |
Definition at line 2567 of file PropertyView.h.
inlineprotected |
Definition at line 2581 of file PropertyView.h.
inlinenoexcept |
false>arrayCount
Definition at line 2615 of file PropertyView.h.
inlinenoexcept |
false>defaultValue
Definition at line 2667 of file PropertyView.h.
inlinenoexcept |
false>description
Definition at line 2608 of file PropertyView.h.
inlinenoexcept |
false>max
Definition at line 2639 of file PropertyView.h.
inlinenoexcept |
false>min
Definition at line 2646 of file PropertyView.h.
inlinenoexcept |
false>name
Definition at line 2596 of file PropertyView.h.
inlinenoexcept |
false>noData
Definition at line 2658 of file PropertyView.h.
inlinenoexcept |
false>normalized
Definition at line 2620 of file PropertyView.h.
inlinenoexcept |
false>offset
Definition at line 2625 of file PropertyView.h.
inlinenoexcept |
Definition at line 2677 of file PropertyView.h.
inlinenoexcept |
false>required
Definition at line 2653 of file PropertyView.h.
inlinenoexcept |
false>scale
Definition at line 2632 of file PropertyView.h.
inlinenoexcept |
false>semantic
Definition at line 2601 of file PropertyView.h.
inlinenoexcept |
false>status
Definition at line 2591 of file PropertyView.h.
protected |
The PropertyView constructor always completes successfully. However, there may be fundamental errors with the property definition. In such cases, this enumeration provides the reason.
This is defined with a class of static consts as opposed to an enum, so that derived property view classes can extend the statuses with their own specific errors.
Definition at line 2681 of file PropertyView.h.
