cesium-native 0.62.0
CesiumGltf::PropertyView< ElementType, true > Class Template Reference
Represents a normalized metadata property in EXT_structural_metadata. More...
#include <CesiumGltf/PropertyView.h>
Inheritance diagram for CesiumGltf::PropertyView< ElementType, true >:
CesiumGltf::PropertyAttributePropertyView< ElementType, true > CesiumGltf::PropertyTablePropertyView< ElementType, true > CesiumGltf::PropertyTexturePropertyView< ElementType, true >
 PropertyView ()
 PropertyView (const ClassProperty &classProperty)
 Constructs a property instance from a class definition only.
PropertyViewStatusType status () const noexcept
 Constructs an empty property instance. false>status
const std::optional< std::string > & name () const noexcept
 Constructs an empty property instance. false>name
const std::optional< std::string > & semantic () const noexcept
 Constructs an empty property instance. false>semantic
const std::optional< std::string > & description () const noexcept
 Constructs an empty property instance. false>description
int64_t arrayCount () const noexcept
 Constructs an empty property instance. false>arrayCount
bool normalized () const noexcept
 Constructs an empty property instance. false>normalized
std::optional< NormalizedType > offset () const noexcept
 Constructs an empty property instance. false>offset
std::optional< NormalizedType > scale () const noexcept
 Constructs an empty property instance. false>scale
std::optional< NormalizedType > max () const noexcept
 Constructs an empty property instance. false>max
std::optional< NormalizedType > min () const noexcept
 Constructs an empty property instance. false>min
bool required () const noexcept
 Constructs an empty property instance. false>required
std::optional< ElementType > noData () const noexcept
 Constructs an empty property instance. false>noData
std::optional< NormalizedType > defaultValue () const noexcept
 Constructs an empty property instance. false>defaultValue
PropertyType propertyType () const noexcept
 Returns the PropertyType of the property this view is accessing.
Protected Member Functions
 PropertyView (PropertyViewStatusType status)
 PropertyView (const ClassProperty &classProperty, const PropertyTableProperty &property)
 Constructs a property instance from a property table property and its class definition.
 PropertyView (const ClassProperty &classProperty, const PropertyTextureProperty &property)
 Constructs a property instance from a property texture property and its class definition.
 PropertyView (const ClassProperty &classProperty, const PropertyAttributeProperty &property)
 Constructs a property instance from a property attribute property and its class definition.
Protected Attributes
PropertyViewStatusType _status
template<typename ElementType>
class CesiumGltf::PropertyView< ElementType, true >
Whether they belong to property tables, property textures, or property attributes, properties have their own sub-properties affecting the actual property values. Although they are typically defined via class property, they may be overridden by individual instances of the property themselves. The constructor is responsible for resolving those differences.
Template Parameters
ElementTypeThe C++ type of the values in this property. Must have an integer component type.
Definition at line 809 of file PropertyView.h.
◆ PropertyView() [1/6]
CesiumGltf::PropertyView< ElementType, true >::PropertyView ( )
Definition at line 817 of file PropertyView.h.
◆ PropertyView() [2/6]
CesiumGltf::PropertyView< ElementType, true >::PropertyView ( const ClassProperty & classProperty)
Definition at line 834 of file PropertyView.h.
◆ PropertyView() [3/6]
CesiumGltf::PropertyView< ElementType, true >::PropertyView ( PropertyViewStatusType status)
inlineprotected
statusThe value of PropertyViewStatus indicating the error with the property.
Definition at line 892 of file PropertyView.h.
◆ PropertyView() [4/6]
CesiumGltf::PropertyView< ElementType, true >::PropertyView ( const ClassProperty & classProperty,
const PropertyTableProperty & property )
inlineprotected
Definition at line 910 of file PropertyView.h.
◆ PropertyView() [5/6]
const PropertyTextureProperty & property )
inlineprotected
Definition at line 926 of file PropertyView.h.
◆ PropertyView() [6/6]
const PropertyAttributeProperty & property )
inlineprotected
Definition at line 942 of file PropertyView.h.
◆ arrayCount()
int64_t CesiumGltf::PropertyView< ElementType, true >::arrayCount ( ) const
inlinenoexcept
false>arrayCount
Definition at line 982 of file PropertyView.h.
◆ defaultValue()
std::optional< NormalizedType > CesiumGltf::PropertyView< ElementType, true >::defaultValue ( ) const
inlinenoexcept
false>defaultValue
Definition at line 1022 of file PropertyView.h.
◆ description()
const std::optional< std::string > & CesiumGltf::PropertyView< ElementType, true >::description ( ) const
inlinenoexcept
false>description
Definition at line 975 of file PropertyView.h.
◆ max()
std::optional< NormalizedType > CesiumGltf::PropertyView< ElementType, true >::max ( ) const
inlinenoexcept
false>max
Definition at line 1002 of file PropertyView.h.
◆ min()
std::optional< NormalizedType > CesiumGltf::PropertyView< ElementType, true >::min ( ) const
inlinenoexcept
false>min
Definition at line 1007 of file PropertyView.h.
◆ name()
const std::optional< std::string > & CesiumGltf::PropertyView< ElementType, true >::name ( ) const
inlinenoexcept
false>name
Definition at line 963 of file PropertyView.h.
◆ noData()
std::optional< ElementType > CesiumGltf::PropertyView< ElementType, true >::noData ( ) const
inlinenoexcept
false>noData
Definition at line 1017 of file PropertyView.h.
◆ normalized()
bool CesiumGltf::PropertyView< ElementType, true >::normalized ( ) const
inlinenoexcept
false>normalized
Definition at line 987 of file PropertyView.h.
◆ offset()
std::optional< NormalizedType > CesiumGltf::PropertyView< ElementType, true >::offset ( ) const
inlinenoexcept
false>offset
Definition at line 992 of file PropertyView.h.
◆ propertyType()
PropertyType CesiumGltf::PropertyView< ElementType, true >::propertyType ( ) const
inlinenoexcept
Definition at line 1030 of file PropertyView.h.
◆ required()
bool CesiumGltf::PropertyView< ElementType, true >::required ( ) const
inlinenoexcept
false>required
Definition at line 1012 of file PropertyView.h.
◆ scale()
std::optional< NormalizedType > CesiumGltf::PropertyView< ElementType, true >::scale ( ) const
inlinenoexcept
false>scale
Definition at line 997 of file PropertyView.h.
◆ semantic()
const std::optional< std::string > & CesiumGltf::PropertyView< ElementType, true >::semantic ( ) const
inlinenoexcept
false>semantic
Definition at line 968 of file PropertyView.h.
◆ status()
PropertyViewStatusType CesiumGltf::PropertyView< ElementType, true >::status ( ) const
inlinenoexcept
false>status
Definition at line 958 of file PropertyView.h.
◆ _status
PropertyViewStatusType CesiumGltf::PropertyView< ElementType, true >::_status
protected
The PropertyView constructor always completes successfully. However, there may be fundamental errors with the property definition. In such cases, this enumeration provides the reason.
This is defined with a class of static consts as opposed to an enum, so that derived property view classes can extend the statuses with their own specific errors.
Definition at line 1034 of file PropertyView.h.
