CesiumGltf::PropertyTablePropertyView< ElementType, true > Class Template Reference
A view on the normalized data of the PropertyTableProperty that is created by a PropertyTableView. More...
#include <CesiumGltf/PropertyTablePropertyView.h>
Inheritance diagram for CesiumGltf::PropertyTablePropertyView< ElementType, true >:
CesiumGltf::PropertyView< ElementType, true >
 PropertyTablePropertyView ()
 Constructs an invalid instance for a non-existent property.
 PropertyTablePropertyView (PropertyViewStatusType status)
 PropertyTablePropertyView (const ClassProperty &classProperty, int64_t size)
 Constructs an instance of an empty property that specifies a default value. Although this property has no data, it can return the default value when PropertyTablePropertyView<ElementType, true>::get is called. However, PropertyTablePropertyView<ElementType, true>::getRaw cannot be used.
 PropertyTablePropertyView (const PropertyTableProperty &property, const ClassProperty &classProperty, int64_t size, std::span< const std::byte > values) noexcept
 Construct an instance pointing to data specified by a PropertyTableProperty. Used for non-array or fixed-length array data.
 PropertyTablePropertyView (const PropertyTableProperty &property, const ClassProperty &classProperty, int64_t size, std::span< const std::byte > values, std::span< const std::byte > arrayOffsets, PropertyComponentType arrayOffsetType) noexcept
 Construct an instance pointing to the data specified by a PropertyTableProperty.
std::optional< PropertyValueViewToCopy< NormalizedType > > get (int64_t index) const noexcept
 Get the value of an element of the PropertyTable, with normalization and other value transforms applied. In other words, the value will be normalized, then transformed by the property's offset and scale, if they are defined.
ElementType getRaw (int64_t index) const noexcept
 Get the raw value of an element of the PropertyTable, without offset, scale, or normalization applied.
int64_t size () const noexcept
 Get the number of elements in this PropertyTablePropertyView. If the view is valid, this returns PropertyTable::count. Otherwise, this returns 0.
- Public Member Functions inherited from CesiumGltf::PropertyView< ElementType, true >
 PropertyView ()
 PropertyView (const ClassProperty &classProperty)
 Constructs a property instance from a class definition only.
PropertyViewStatusType status () const noexcept
 Constructs an empty property instance. false>status
const std::optional< std::string > & name () const noexcept
 Constructs an empty property instance. false>name
const std::optional< std::string > & semantic () const noexcept
 Constructs an empty property instance. false>semantic
const std::optional< std::string > & description () const noexcept
 Constructs an empty property instance. false>description
int64_t arrayCount () const noexcept
 Constructs an empty property instance. false>arrayCount
bool normalized () const noexcept
 Constructs an empty property instance. false>normalized
std::optional< NormalizedType > offset () const noexcept
 Constructs an empty property instance. false>offset
std::optional< NormalizedType > scale () const noexcept
 Constructs an empty property instance. false>scale
std::optional< NormalizedType > max () const noexcept
 Constructs an empty property instance. false>max
std::optional< NormalizedType > min () const noexcept
 Constructs an empty property instance. false>min
bool required () const noexcept
 Constructs an empty property instance. false>required
std::optional< ElementType > noData () const noexcept
 Constructs an empty property instance. false>noData
std::optional< NormalizedType > defaultValue () const noexcept
 Constructs an empty property instance. false>defaultValue
PropertyType propertyType () const noexcept
 Returns the PropertyType of the property this view is accessing.
Additional Inherited Members
- Protected Member Functions inherited from CesiumGltf::PropertyView< ElementType, true >
 PropertyView (const ClassProperty &classProperty, const PropertyTableProperty &property)
 Constructs a property instance from a property table property and its class definition.
 PropertyView (const ClassProperty &classProperty, const PropertyTextureProperty &property)
 Constructs a property instance from a property texture property and its class definition.
 PropertyView (const ClassProperty &classProperty, const PropertyAttributeProperty &property)
 Constructs a property instance from a property attribute property and its class definition.
- Protected Attributes inherited from CesiumGltf::PropertyView< ElementType, true >
PropertyViewStatusType _status
template<typename ElementType>
class CesiumGltf::PropertyTablePropertyView< ElementType, true >
It provides utility to retrieve the actual data stored in the PropertyTableProperty::values like an array of elements. Data of each instance can be accessed through the get method.
ElementTypemust be one of the following: an integer scalar (uint8_t, int8_t, uint16_t, int16_t, uint32_t, int32_t, uint64_t, int64_t), a glm vecN composed of one of the integer scalar types, a glm matN composed of one of the integer scalar types, or PropertyArrayView<T> with T as one of the aforementioned types.
Definition at line 628 of file PropertyTablePropertyView.h.
◆ PropertyTablePropertyView() [1/5]
CesiumGltf::PropertyTablePropertyView< ElementType, true >::PropertyTablePropertyView ( )
Definition at line 637 of file PropertyTablePropertyView.h.
◆ PropertyTablePropertyView() [2/5]
CesiumGltf::PropertyTablePropertyView< ElementType, true >::PropertyTablePropertyView ( PropertyViewStatusType status)
statusThe value of PropertyTablePropertyViewStatus indicating the error with the property.
Definition at line 651 of file PropertyTablePropertyView.h.
◆ PropertyTablePropertyView() [3/5]
CesiumGltf::PropertyTablePropertyView< ElementType, true >::PropertyTablePropertyView ( const ClassProperty & classProperty,
int64_t size )
classPropertyThe ClassProperty this property conforms to.
sizeThe number of elements in the property table specified by PropertyTable::count
Definition at line 674 of file PropertyTablePropertyView.h.
◆ PropertyTablePropertyView() [4/5]
CesiumGltf::PropertyTablePropertyView< ElementType, true >::PropertyTablePropertyView ( const PropertyTableProperty & property,
int64_t size,
std::span< const std::byte > values )
inlinenoexcept
propertyThe PropertyTableProperty
valuesThe raw buffer specified by PropertyTableProperty::values
Definition at line 710 of file PropertyTablePropertyView.h.
◆ PropertyTablePropertyView() [5/5]
int64_t size,
PropertyComponentType arrayOffsetType )
inlinenoexcept
arrayOffsetsThe raw buffer specified by PropertyTableProperty::arrayOffsets
arrayOffsetTypeThe offset type of arrayOffsets specified by PropertyTableProperty::arrayOffsetType
Definition at line 739 of file PropertyTablePropertyView.h.
◆ get()
std::optional< PropertyValueViewToCopy< NormalizedType > > CesiumGltf::PropertyTablePropertyView< ElementType, true >::get ( int64_t index) const
inlinenoexcept
If this property has a specified "no data" value, and the retrieved element is equal to that value, then this will return the property's specified default value. If the property did not provide a default value, this returns std::nullopt.
indexThe element index
The value of the element, or std::nullopt if it matches the "no data" value
Definition at line 770 of file PropertyTablePropertyView.h.
◆ getRaw()
ElementType CesiumGltf::PropertyTablePropertyView< ElementType, true >::getRaw ( int64_t index) const
inlinenoexcept
If this property has a specified "no data" value, the raw value will still be returned, even if it equals the "no data" value.
Definition at line 838 of file PropertyTablePropertyView.h.
◆ size()
int64_t CesiumGltf::PropertyTablePropertyView< ElementType, true >::size ( ) const
inlinenoexcept
The number of elements in this PropertyTablePropertyView.
Definition at line 865 of file PropertyTablePropertyView.h.
